Beiträge von ondrik363
    I checked the links - from my computer it works. The magnetic switches must be NO .. If the doors are closed, circuit it must be open. Your magnetic switches are also good, you can choose which contact you want to use (NC or NO)
    But, using and assembling this mini little switches is problematic.
    I have these:
    What we want to need:
    4 door lights, 4 magnetic switches (NO - normally open), pins for door connectors.
    lights
    switches
    pins
    Connecting lights and switches is simple, I won't draw that. The power supply is via the new pins in the door, it is connected from the anti-fire circuit, board computer, connector E, pin 9. If you leave the door open for more than 15 minutes, the lights will turn off automatically. If you close the door and leave it open again, the lights will come back on for 15 min...
    schematic:
    hi there
    yeah steering wheel 500x
    is it tricky to change it or "plug & play" ? (the heating wiring unregarded)
    do you satisfied with witson? because i´m not and kicked it in the bin and custom installed an 9" joying unit. ;)
    Steering wheel is plug&play..Heated element not...
    I am satisfied with Witson, for my using is good. I have Witson with DSP, sound is super, without interference..I added small cooling fan, and i adjusted the holder of display, because it was soft for touching. Only one thing - FM reception is worse that original uconnect. But i am listening internet radio app, or DAB+ usb stick. Most often apps that i am using are - youtube, navi, DPF monitor, google maps , hands free - no problem on my Witson.Everything works fine. MCU version - V3.78.
    Hello.Hi. I am from Slovakia and I own a Fiat Tipo SW. I bought it 2 years ago, year of manufacture 2018, 1.6 mjet 88kw, 30 000km. I bought it from Poland. All equipment except xenons and electric lumbar support.. I bought it 2 years ago, year of manufacture 2018, 1.6 mjet 88kw, 30 000km. I bought it from Poland. All equipment except xenons and electric lumbar support. If you need a scematic, circuit diagrams- no problem, i have all...
    My "tuning" :
    IAM (inteligent alternator module) - OFF (proxi AlfaOBD)
    S&S system - OFF (proxi AlfaOBD)
    Added stuff:
    Steering heated wheel from fiat 500x
    Paddle shifters from fiat 500x
    Front parking sensors - Steelmate
    Android head unit - Witson
    Led H7 - Low + High beam
    Reverse Led light
    Front + rear camera
    Etc.....
    Few pictures
    https://postimg.cc/fVSNmKCj[/img]
    https://postimg.cc/p9NtZF1N[/img]
