Beiträge von Alothman
    This is the original proxy
    33 36 33 35 36 30 32 33 31 35 35 4F 55 54 50 55 54 44 4A 49 54 20 16 07 10 4F 04 00 05 10 00 00 02 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 02 00 00 00 00 00 00 00 00 51 F9 05 02 A4 15 07 8D D0 29 02 07 42 10 00 03 A3 28 04 82 01 35 63 14 00 4F 03 34 1B 83 08 00 3F 00 05 00 A0 00 00 00 00 00 10 81 00 25 02 5A 00 07 04 AD 00 4E 00 01 A3 10 00 40 00 01 00 C7 00 D5 00 00 00 00 49 01 01 14 70 62 00 00 00 01 00 80 70 00 01 29 C0 00 80 00 05 00 00 00 00 00 00 00 00 00
    sorry, here you write, you didn't save the proxy and use this one. You need the proxy for this car, not a proxy of the same equipment, it must be the original proxy for the car when delivered. Then Carplay may no longer work and then the ACC will also work if it was originally in it.
    But as I said, the radar will no longer work properly anyway and has to be calibrated by a workshop. Once again: no hardware of the vehicle is destroyed during a proxy alignment.
    Es stimmt, dass ich es nicht gespeichert habe, als ich an der Ausrichtung gearbeitet habe, sondern auf meinem Laptop gefilmt habe, was zu tun war
    Denn nur wenn beispielsweise beim Fahren ein Auto vor mir stoppt, erscheint eine Bremswarnung
    Die Frage, wer dafür verantwortlich ist, liegt nicht beim ACC oder gibt es etwas anderes?
    Who wrote you to expand the radar? Nobody wrote that the radar is broken. You are doing things that no one has written here!
    How do you get the idea that the radar is broken due to Carplay activation. You don't understand the function of the proxy file at all! Because then you would have known that you cannot destroy any components on the vehicle! This file contains the vehicle configuration. You cannot simply copy this file from one vehicle to another!
    It's too late now. You can't align the radar, you have to go to the workshop now!
    I reinstalled the original proxy too, but that idiot's acc is not working
    Ich vermute mal ganz stark, er benutzte nicht den blauen Adapter :/ Es ist immer wieder erstaunlich, was Leute sich so zutrauen ohne entsprechendes Hintergrundwissen.
    Jetzt muss eh zur Werkstatt fahren um alles wieder in Ordnung bringen zu lassen.
    Ich benutze natürlich dieses blaue Stück. Meine Frage war, woher ich weiß, ob das Radar kaputt ist oder nicht. Ich weigere mich, zum Agenten zu gehen, natürlich wird es mir eine Menge Geld kosten
    Ich glaube multiecuscan legt immer eine logdatei an. Dort ist die Proxy meiner Meinung nach hinterlegt. Da könntest du die originale wieder herbekommen. Manchmal treten Fehler beim ausrichten auf, dann das ganze nochmal probieren. Wichtig ist auch die richtige formatierung.
    Wenn alles nicht klappt musst du in die Fiat-werkstatt fahren.
    Hast du den Sensor ausgebaut? Wenn ja musst du eh in die Werkstatt um den neu einstellen zu lassen....🫣
    حسنًا، كان ذلك غبيًا حقًا وتم ارتكاب العديد من الأخطاء.
    ستحتاج إلى سيارة مقارنة بمعدات ومحرك وسنة تصنيع متطابقة، وما إلى ذلك... ثم استبدل BC الخاص بك بسجل البيانات منه ثم قم بتنشيط carplay/Android Auto بشكل منفصل.
    Wie kann ich den ursprünglichen Proxy für mein Auto wiederherstellen?
    Tja das ist wirklich blöd gelaufen und mehrere Fehler gemacht worden.
    Du bräuchtest ein Vergleichsauto mit identischer Ausstattung, Motor, Baujahr usw... Dann mit dem Datensatz davon dein BC wieder überschreiben und dann separat carplay/Android Auto freischalten.
    Was soll ich tun? Sagen Sie mir bitte, dass ich angefangen habe, Fehler zu bekommen
    Ich habe den ursprünglichen Proxy wiederhergestellt, aber wenn ich den Proxy ausrichte, erscheint beim Schreiben ABS in das System ERORR. Jetzt erscheinen das Frame-Check-System und die Traktionskontrolle bei Geschwindigkeit 30. Vielleicht habe ich etwas zerstört, als ich einen falschen Proxy eingesetzt habe
    Du hast den alten nicht gespeichert?
    Das ist schlecht. Sehr schlecht!
    Hast du die kompletten Bytes so von irgendwo kopiert und eingefügt? Oder nur die letzten Bytes zugefügt?
    Wenn du die kompletten Bytes so von irgendwo her übernommen hast, dann hast du Mist gebaut. Dann kannst du froh sein, dass nur ACC nicht funktioniert.
    Ah okay. Jetzt habe ich es verstanden. Hmm.
    Seltsam. Also normalerweise passiert das nicht. Es sei denn man hat ausversehen ein falschen Byte geändert.
    Alte Proxiausrichtung wieder herstellen und schauen ob es dann wieder geht. Und dann Carplay nochmal neu aktivieren.
    Ich kenne den ursprünglichen Proxy, ich habe ihn nicht gespeichert und diesen verwendet 33 36 33 35 36 30 31 30 35 36 33 4F 55 54 50 55 54 44 4A 49 54 20 16 06 08 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 53 F9 05 02 A4 15 07 8D D0 29 07 07 42 10 00 03 A3 28 04 82 01 35 63 14 00 4F 03 34 01 83 08 00 21 00 03 00 A0 00 00 00 00 00 10 81 00 25 01 5A 00 07 04 B5 00 4E 00 01 A1 10 00 40 00 01 00 C7 00 D5 00 00 00 00 49 00 05 14 70 62 00 00 01 01 00 80 70 00 01 29 C0 00 80 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
    آه حسنا. الآن أفهم ذلك. همم
    غريب. لذلك لا يحدث هذا عادة. إلا إذا قمت بتغيير بايت خاطئ عن طريق الخطأ.
    قم باستعادة محاذاة الوكيل القديمة ومعرفة ما إذا كانت تعمل مرة أخرى. ثم أعد تمكين Carplay.
    لا أعرف البروكسي الأصلي، ولم أحفظه، واستخدمت هذا البروكسي : 33 36 33 35 36 30 31 30 35 36 33 4F 55 54 50 55 54 44 4A 49 54 20 16 06 08 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 0 0 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 53 F9 05 02 A4 15 07 8D D0 29 07 07 42 10 00 03 A3 28 04 82 01 35 63 14 00 4F 03 34 01 83 08 00 21 00 03 00 أ0 00 00 00 00 00 10 81 00 25 01 5A 00 07 04 B5 00 4E 00 01 A1 10 00 40 00 01 00 C7 00 D5 00 00 00 00 49 00 05 14 70 62 00 00 01 01 00 80 70 00 01 29 ج0 00 80 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0 0 00 00 00 00 00 00 00 00 00 هل يمكن أن تخبرني ما هو البايت الخطأ ؟ شكرًا
    يعمل نظام التحكم في السرعة (ACC) فقط إذا كان لديك مساعد الفرامل، أي أن لديك بالفعل جهاز استشعار الرادار. وبعد ذلك بالطبع تحتاج إلى أزرار عجلة القيادة لذلك.
    Können Sie mir das genauer erklären? ACC funktionierte, bevor ich Apple CarPlay nutzte, jetzt nur noch Tempomat
    Hallo zusammen, ich bin neu hier, gestern habe ich Apple CarPlay aktiviert, aber die ACC-Programmierung verloren. Gibt es eine Möglichkeit, es zu aktivieren? Vielen Dank.
