Beiträge von Betameche
    Streitigkeiten gibt es überall.
    Was hier in dem Forum abgeht ist nicht schlimmer als das was ich aus Familie, Verein und Kirchengemeinde kenne.
    Ein paar Tage im Schmollwinkel bleiben wenn es zu hart kommt aber komplett abmelden nein.
    "Etwas Besseres als den Tod findest du überall" heisst es bei den Bremerstadtmusikanten. In dem Sinne viel Glück bei der Suche nach einer anderen Gemeinschaft.
    Bei der Vorstellung des Motors war die Rede von 250.000km Laufleistung für die Steuerkette. beim 1,3l Multijet (Diesel).
    Aus meiner Erinnerung - leider nichts Schriftliches.
    Aus den Internet
    autospruce.com/1-3-multijet-cdti-ddis-engine-problems-reliability/
    Valve Train Chain
    The timing chain on the 1.3 Multijet, CDTI or DDiS engine is controversial. Is it stretching or not? When to change it? There are even rumors that the plant is planning to replace it every 120,000 km. It is also rumored that on some 1.3 Multijet / CDTI engines the chain traveled 500,000 km without replacement.
    In practice, in most cases, the chain resource ends by 200,000 km, and it is better to replace it preventively. Because at critical wear, it simply breaks. And there are a lot of cases of engine damage due to an open circuit.
    The stretched timing chain of this motor does not rattle too noisy, so not all owners notice its extraneous noise in time. The chain resource is greatly reduced if the driver leaves the car in gear on a slope, drives in tight gear in higher gears.
    The chain tensioner overhang on the 1.3 Multijet, CDTI or DDiS engine can be seen through the inspection window in the timing cover, but on the machine, the upper engine mount must be removed to access it. The maximum overhang of the tensioner is 20 mm, overhang with a new chain is about 3 mm.
    The chain must be changed together with its guides and hydraulic tensioner, because it often wears out and loosens. It is also worth assessing the wear on both timing gears and changing them if necessary.
    Da keiner der genannten Punkte richtig erfüllt ist, ist eine Impfpflicht weder moralisch noch rechtlich implementierbar.
    Zum Rechtlichen kann ich nichts sagen.
    Moralisch: Daran arbeiten die christlichen Theologen im Ethikrat. Dabei sind sie bisher zum Ergebnis gekommen, dass unterschiedliche Behandlung von Geimpften und Ungeimpften nicht verwerflich sei und keine Spaltung der Gesellschaft bedeute.
    Irgendwie bin ich zu blöd um hier Bilder hochzuladen...
    Nein, bestimmt nicht. Bilder dürfen hier nicht größer als 1MB sein. In der Gallerie 2MB. Beim PC einfach mit der Maus ins Textfeld ziehen oder unten im Reiter "Dateianhänge" Schaltfläche Hochladen wählen.
    Wenn ich mir das Bild mit den Daten ganz oben ansehe: Von dem Anbieter würde ich nichts kaufen. Der weiss nicht mal die Größe der Radschrauben.
    Denk' an den alten Satz: Wer billig kauft kauft doppelt. Also ab zu einem seriösen Reifenhandel. Vor 20 Jahren gab es so was auch in Berlin, ob heute noch?
    Sabine Deckenbach: Weder braucht es ein "Ende der Solidarität mit Ungeimpften", noch sind die Österreicher Tiere, bei denen "man die Zügel enger ziehen muss".
    Stellungnahme einer österreichischen Kommunalpolitikerin zu den gesellschaftlichen Randerscheinungen der Corona-Krise. (Dauer 09:37 min)
    rumble.com/vp8nit-die-rote-linie-ist-berschritten.html
    "Lehne das Automobil grundsätzlich ab..." ...in einem Auto-Forum
    Auch darüber kann man in einem Auto-Forum diskutieren. Aber dann bitte nicht unter der Rubrik "Mitgliedervorstellung". Schon deshalb nicht weil Mitglied Fee das Auto nicht ablehnt.
    Mir ist klar, dass mein Beitrag völlig überflüssig ist und die Diskussion nur unnötig verlängert. Also erspart euch eine Antwort, damit hier endlich ein Ende ist.
    morgen wäre die Trauerfeier für meinen Vater gewesen.....habe ich mal gleich meine Teilnahme abgesagt......
    Erstmal mein Beileid,
    war vergangene Woche auf einer Trauerfeier. Alle haben mit ihren Impfausweisen in der Luft rumgewirbelt und ich wurde wie ein Außerirdischer angestarrt, weil ich eine Maske trug. Für mich ist der Impfnachweis kein Freifahrschein auch wenn die Politik es den Leuten glauben machen will. Angsichts der hohen Zahlen und der Möglichkeit, dass auch Impfausweisbesitzer erkranken und die Krankheit weitergeben könnten, ist die Maske ein unvermeidbares Muss.
    Dann wirst du uns bei der Lösung FIAT TIPO spezifischer Probleme nicht mehr zur Verfügung stehen. Was hatte ich denn die letzten 3 Jahre für Sorgen mit dem TIPO?
    Wartezeit, beim Trabant waren es rund 12 Jahre. Scheint bei Skoda arbeitet man daran.
    Wenn der Wagen dann in 12 Monaten geliefert wird, wird's Vormittag oder Nachmittag. Damit der Klempner nicht vor der Türe steht, während man das Auto abholt. (Alter DDR-Witz)
    Ach ja der Karneval:
    Der vollständig geimpfte Prinz ist positiv getestet und das geimpfte Volk besteht nicht aus verantwortungsbewussten Superhelden sondern aus Narren. Das ist doch das Wesen des Karnevals oder?
    Mal sehen wie das Experiment ausgeht. Werden die rheinländischen Karnevalshochburgen begl. der Infektions- und Hospitalisierungszahlen den Anschluß an die bayerischen Landkreise schaffen?
